my 2360 bx engine speed began to slow down intermittently every 20-30 seconds and when engine is slowed and tractor is under load, it may stop the engine completely. Is this a fuel line problem or an electrical problem? Any ideas?
Check your air filter, fuel filter and petcock as mentioned, and if the fuel level is down, see if you can see any blockages in the bottom of the fuel tank.
Welcome to OTT, by the way!
First off welcome,, secondly if theres a petcock on the 2360 I aint found it on mine,, and I would surely change out the fuel filters,, Now have you run any Bio disel through your little beast,, cause if you have then it will clean all kinds of crud out of the lines and clog up the filters.. And you might want to pull the air filter off and check it too,, are you getting any smoke?
A dumb question but what about fuel? Is it fresh have you added anything to the fuel? Have you drained the tank and refilled with new fuel?
Keep us posted
