I bought this tractor yesterday. I am still learning about it but the manual is not helpful.
A branch came under the tractor and pulled off a rubber hose on the right side of the tractor. It also dislodged a metal hose that I am sure goes to the front end loader. As soon as this happened the power steering went out then the front end loader. Lots of hydraulic fluid poured out.
I reattached the rubber hose but then I found the metal hose still leaking at the attachment point.
I can not find the dipstick anywhere to check the hydraulic fluid nor where to put fluid in. Also does this same fluid go to the transmission?
The rear brush cutter still raises and lowers.
Thanks for all the help.
