MX5800 Lift Arms Won't Raise
scatman
b2601 mx5800
May 21, 2026
10
Sacramento
I just removed the hydraulic Cylinder case to change the lift arm shaft and replace the o-rings and I put it back together and now the arms are not lifting at all? Any idea what the problem can be?
Caden
1979 B7100
Apr 16, 2026
249
125
My first guess would be trapped air.
My second guess it that when you reassembled everything, the piston/rod is out of time with the lift arm. As in not aligned on the spines correctly.
@North Idaho Wolfman is probably the guy you most want to hear from in this case.
7,235
Trapped air has absolutely nothing to do with it.
My first guess is you have the rockshaft arm/pushrod out of whack. Another possibility is the feedback and position control linkage is fubared.
scatman
b2601 mx5800
May 21, 2026
10
Sacramento
I double checked the spline with the dot and aligned correctly.
7,235
No it does not
If you hear the relief activate when you pull the rod the position control valve is opening and the hudraulic system is deadheading. That means you have pressure to the valve.
If the lift does not come up the piston is not pushing on the rock shaft lever or you dont have pressure to the piston. What if anything did you do to the valve?
11,042
Take a couple pictures of the linkage and arms on both sides.
scatman
b2601 mx5800
May 21, 2026
10
Sacramento
We didn’t touch the valve, that’s why I’m so confused
7,235
Move the lift arms to push that rod as far in as possible and take a picture of the lift arm position in that state.
Why did you take this apart in the first place?
