MX5400/MX6000 Cab model
edritchey
2021 Ferris IS800Z - 2025 New Holland CNH WM75
Jul 19, 2014
1,139
855
Wellsville, PA
Does anyone know if a right side door latch like the one on the left door is available sure would make reaching inside to move the 3 point arms a lot easier. I always forget to unlatch the door from the inside before I gat out. :). I didn't see anything in the parts manual.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I would talk to your dealer, but I see what you mean. I checked the parts list for that machine. The only thing I can think of is to get the entire assembly from something like a grand L series. I think Messicks may have a video about the mx6000 and possibly up grades.
troverman
Jun 9, 2015
1,178
266
NH
I just bought an MX6000 cab. I had the dealer order the parts to get the RH latch. $376 in parts, so it can be done. Like you, I reach in to operate the 3 point hitch height while hooking to an attachment. I also will open that door to start the engine sometimes. The MX cab is the same as the Grand L cab, but it is also missing the latches to open the rear quarter windows. These could be added, but the glass would need to be drilled and the hinges added also. I guess that’s why the Grand L costs more…
edritchey
Jul 19, 2014
1,139
855
Wellsville, PA
I just installed the right side door latch parts on our new MX cab model tractor I really think Kubota should have made them standard with these parts.
edritchey
Jul 19, 2014
1,139
855
Wellsville, PA
Couple pictures of the right hand door with a latch like they come with on the left side In my opinion these machines should come from Kubota with this door latch instead of the cheap garbage that they ship with.
troverman
Jun 9, 2015
1,178
266
NH
I agree. The dealer is doing this to my MX6000 as we speak - I could certain do it myself, but its a brand new machine so they are doing it as part of the prep. I've also wondered about retrofitting the right-side step like the Grand L 60 machines have. However, they don't have the valve in the same place. Not as big a deal to me, since I don't try to get in and out on the right side. And keep in mind most of the competition does the same thing as Kubota...left side access only, right side emergency exit. I just think if you go to all the trouble of an entire opening glass door, why not make it easy to open from the outside?
10,386
edritchey
Jul 19, 2014
1,139
855
Wellsville, PA
That's a nice upgrade, and now on my wish list.
I know Kubota doesn't want you to step on the loader valve cover and that's why they don't give you the right side latch but I just needed a better way to get in that side of the tractor to access the controls and the latch just made sense for me. It took me maybe 20 minutes to install the parts I think the parts are way over priced but it is what it is.
troverman
Jun 9, 2015
1,178
266
NH
They don’t include the latch to keep the price down, and because the competition doesn’t include a latch either.
troverman
Jun 9, 2015
1,178
266
NH
Beat me to.
I stopped at the dealer to drop off my Bro-Tek rear spacers. Should be able to take delivery by the end of the week I hope.
3,826
I wonder how many cowpokes saddle-up on the off-side… :unsure:
What would truly be helpful would be in tractor mfr’s would standardize rear-access to 3-pt controls. Some models have that feature. I’ve considered welding a short extension to my 3-pt lift-control beneath the open-station. (It was a really simple matter to change implements on the old Ford N.) 🤣
10,386
Thanks to @edritchey and @troverman for this information. I finally got around to doing something about this upgrade. I use the right side door on the M6060 regularly, and many times have wanted to access the right door on the MX but it's a pain of course. The price at Messick's is now $381.02 for the necessary parts, so not a big jump over the 2022 pricing. I emailed the local dealer to see if the price is any better. I have a credit with them so if they can bring the parts in for close to Messick's price I'll go that route.
Current part numbers needed:
010 COMP LOCK, DOOR COMP.LOCK DOOR RH
T0270-86010
070.1 ASSY HANDLE,OUTER. replaces #T0270-85100
T0270-85102
110 COVER COVER,DOOR LOCK RH
T0270-86150
120 KNOB KNOB,DOOR LOCK
T0270-85140
130 KNOB KNOB,INNER LOCK
T0270-85160
140 SCREW SCREW
T0270-85130
150 ROD ROD,CY LINDER
T0270-85070
160 BOLT BOLT,SEMS
01023-50612
170 STRIKER, DOOR LO STRIKER, DOOR LOCK
T0270-85170
190 NUT NUT,DOOR STRIKER
T0270-70890
200 SCREW SCREW ,CSKH
3F760-53430
210 W ASHER, TOOTHED, WASHER,TOOTH CONICAL
04414-50080
10,386
Another update. I emailed the local dealer the list above and my cost including shipping is $377.71 and all the parts will be here Thursday or Friday of next week. Since Thursday is July 4th I assume that it'll be Friday.
I should have got a handle on this a couple of years ago! Pun intended! 😂
Also, three of the parts in the list I posted above need to be ordered in quantities of two.
T0270-86010
T0270-85102
T0270-86150
T0270-85140
T0270-85160
140 SCREW SCREW (2 each)
T0270-85130
T0270-85070
160 BOLT BOLT,SEMS
01023-50612
T0270-85170
T0270-70890
200 SCREW SCREW ,CSKH (2 each)
3F760-53430
210 W ASHER, TOOTHED, WASHER,TOOTH CONICAL (2 each)
04414-50080
