Mower deck question
Warthog1001
2008 BX2200
May 5, 2026
UK
Apologies, this is an issue with a non-Kubota deck; but the only reason I end up posting is that my BX2200 is out of action for a gearbox repair on the RCK54 deck, so I feel semi-justified.. I resorted to mowing the paddock with a vintage Massey-Ferguson 30-15 (belonged to my dad, stored for 30 yrs) which was doing fine until the deck drive belt slipped off. On examination there is a huge amount of slack in the belt, as if the tensioner arrangement has failed.
I dropped the deck - approx 42", no manufacturer plate - but can't understand what has happened; the belt tensioner sheave is mounted on a swivelling arm, as usual. To apply belt tension the sheave must be pulled towards the 8 o'clock direction in these pictures yet the only spring attached to the arm is pulling it in the 12 o'clock direction. The spring is wrapped rather crudely around the black plastic air ducting at the front end of the deck on which there are some wear marks but it does not look as if the mounting has moved.
I can't find a manual for this vintage MF tractor or deck; also did not find any stray springs in the grass where I suddenly lost drive to the deck. Can anyone explain what's missing and/or how to fix?
SDT
Apr 15, 2018
3,622
1,348
Might want to post this in the MF forum on TBN and/or YT.
Caden
1979 B7100
Apr 16, 2026
77
Hmm...
I'm guessing the wear on the ductwork is from the mower transaxle belt when the deck is raised.
That spring looks too specific not wrap around the ductwork although it is an odd system.
It looks like that fan pulley is only barely catching the belt like it is now, which seems off.
How about this something like this? All I can figure, so that you are pulling against the spring and around the fan pulley completely.
pigdoc
G1800S L2500
Aug 19, 2022
397
337
SE Pennsylvania
Man, that deck is TOAST! I can see rust holes all over it.
I would guess that the pin that the tensioner spring normally hooks to took an unannounced leave-of-absence. Previous operator tried to compensate.
I'd probably just try to find another spot to hook the tensioner spring.
Shorten the spring as necessary to gain belt traction.
-Paul
