armylifer
I have mentioned a few times in this forum about using my BX1860 to move heavy rocks on my property. I have never provided pictures or details before. Well, it is time that I fixed that. Today I was moving rocks again and I stopped to take a few pictures.
I estimate this load to be ~650 lbs. If I took the weights off from the back of the tractor this load would have lifted the rear wheels off the ground. I know this because before I added the weights this regularly happened. The rear tires have about 7.5 gallons of water in each one of them. I estimate that to be about 105 lbs. The weights on the rear are another 230 lbs. Even with this much ballast the rear tires slip on the wet grass (but not on dry grass) so I have to drive in 4wd in low range. If my property was not so flat I would not attempt to move this much weight. BTW, the front tires are also loaded with water but they do not provide ballast as they are actually the pivot point when the bucket is loaded. However loading the front tires provides me the ability to carry these heavy loads without causing the front tires to compress too much.
Before anyone comments that this looks unsafe please remember what I said about my property being flat. Therefore I do not experience any problems with load instability.
