Moving rear tires out on a b7100
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
176
Freeland, mi
I don't know anything about your tractor but I looked up info on tractor data. It gives three different widths for the rear wheels. I don't know if that means you need a different wheel and tire combo or if you can adjust what you have in and out. Good luck.
Sent from my moto z4 using Tapatalk
3,581
By moving the hubs out, reversing them, (if necessary) and reversing the rims, (if necessary) you should be able to get them almost outside the rear fenders. My neighbor's B2150 uses the same setup as my B7100, and he has his rear tires completely outside the rear fenders. Looks a little funny, but it's stable. You can kinda see how far out they are in the pic, only one I have of his setup.
SDT
Apr 15, 2018
3,703
1,421
Can I move them all the way out
IIRC, the B7100 has hexagonal axles with adjustable hubs as does my B1750.
You can move the hubs out such that the ends of the hubs are flush with the ends of the axles.
Be certain to properly tighten the hub clamps after adjustment and retighten after a period of use.
SDT
