D Dirt Mover Member Jan 9, 2014 58 2 8 Delaware Monday at 2:11 PM #1 I have a B3350 with loader. If I want to install a grapple, Do I need additional plumbing / control valve? Dirt mover
MapleLeafFarmer Well-known member Equipment Lots incl. B and L kubotas Dec 2, 2019 1,113 1,105 113 E. Monday at 2:14 PM #2 depends. - some grapples are mechanical and do not require any hydraulic access. - if your tractor has a third function setup in place then you re good to go if y0ou choose a hydraulic grapple. - you could install a diverter valve - etc... more info needed
Kennyd4110 Well-known member Vendor Member Sep 7, 2013 1,507 888 113 Westminster, MD www.boltonhooks.com Monday at 2:40 PM #3 Generally, yes. But as @MapleLeafFarmer write, more info needed. Budget? Grapple Style? Loader model number?
F fruitcakesa Well-known member Equipment M4 071 Oct 26, 2010 879 304 63 Cavendish Vermont Tuesday at 8:22 AM #4 Until I got my M4 with 3rd function, on my earlier tractors I would run hoses from the rear remotes to the grapple.
