Mosquito larvae in rain barrel
jaxs
B1750HST
Jun 22, 2023
1,060
799
Or cistern tank shouldn't be treated with insecticides so I thought I'd share some safe solutions. Sheet plastic or wax paper kitchen wrap gently spread on surface will stay on surface as long as not disturbed. If kept in place continuously, 10% surface coverage is adequate but if wigglers are already present, 25% or more coverage is advisable. Larvae must surface often to breath via special tube and this blocks access to air. An alternate requiring more preparation but works better where surface is disturbed by wind,birds or such. Just to give you idea how it works,some of those little Styrofoam hats used for faucet freeze protection do well. Pull stopper,submurge 50%,replace stopper and let go. There's a strong vacuum in air space inside cup that pulls larvae inside-out the moment his guzzle breaks surface. To fabricate a larger version, cut upper portion,including cap from plastic, 5 gallon distilled water jug, split and glue a fat pool noddle around rim. There's plenty options using Fed-X packing and discarded plastic containers. As long as container is highly buoyant there's no need for cap/plug. Partly submerge then flip container into position.
A tablespoon of most any oil will cover a few sq feet surface to accomplish same thing but makes a terrible mess when emptying barrel. Vegetable oil doesn't harm irrigation water but again it sure makes barrel slick.
Floating containers do fairly well in livestock troughs but for large tanks I place a few small fish/minnows in them each Spring.
3,037
There is also Mosquito Dunks that contain BT That you can use.
I don’t know what you use the cistern water for but I think this is pretty safe method.
Here is a link to a specific product
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
410
289
Bayview Township
Have been using the BT chips for a couple decades or so. I just drill holes into used jam jars, attach a string, and add the chips. Need the string to pull out the jars and recharge with fresh chips and "tea bag" the jar occasionally to better distribute the bt in the water. Maybe not necessary , but just in case. Less $$s than the dunks. Chips at the end of the growing season are cleaned out of the rain water irrigation "tanks" and composted.
OP's idea would be less $$s.
4,165
Or just get a few guppies, they will eat all the bugs
Depending upon what the water is eventually used-for….. fish poop in the water….
We put goldfish and koi in our cattle-tanks.
The raccoons love ‘em.
Another method is Liquid Monolayer Films which not only reduce surface evaporation on ponds but also constrols mosquito larvae.
