More M9540 questions on heater core
texczech
10
I am looking at replacing the blower motor, but it also seems that the heater core is leaking... WOW- have you priced one for this tractor- pn 590-6024. It seems awfully expensive. I wonder if there are any alternatives or a plan B?
BAP
Dec 31, 2012
2,559
688
Take it to a good radiator shop and see if it can be repaired
SidecarFlip
Banned
550
It may be aluminum, I am not sure a radiator shop can handle that.
Good one can. Only time it becomes a throw away is if the end tanks are plastic because they are glued on and removal destroys the rad.
4,908
1,635
If it is aluminum, it "might" could be fixed. If the leak(s) are in the middle of the tube somewhere, what they'll do is clean it up really well using a solvent, then apply a vacuum to the core. Once it's got vacuum on it, they'll KEEP the vacuum on it, then apply their sealant if they can get to the leak(s), which sucks the sealant into the leaks and let it cure a while. Afterward, pressure test and fix other leak if there are any. If for some reason they can't fix the leak(s), they will give it back to you, ask you to pay the testing/diagnosis bill, and you get to buy a new one.
I've addressed quite a few heater cores and what I have noticed is that the #1 cause for leakage is failure to replace the coolant or in rare cases it just gets damaged physically.
Sometimes they are not repairable.
