Mini excavator auger for a BX23s backhoe
GreenBarnAcres
BX23S
Jul 30, 2024
E3B 2X6
Hi there,
Rather than a 3-point auger, has anybody looked into getting a mini excavator auger to work with the BX23s backhoe? Thank you!
whatsupdoc
L3302
Jul 9, 2024
176
199
While you could mount the auger to the backhoe the BX23's hydraulic
flow rate is very low, something like 3.7 GPM. It may not have the flow
to drive the auger properly.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
714
831
NE FL
It should ru but slow. I adapted a mini ex sickle bar mower to run off my 3rd function and it works.
I bought one of the augers but flipped it before trying it.
EPIC
KX040-5
Jul 12, 2026
23
Florida
They make different size augers that require different amounts of hydraulic flow, and can run different size bits.
If you want to try it, check the specs and get the closest you can to your flow and pressure.
Just as an fyi if it turns too slow it won’t remove dirt from auger, you might need to do that by hand. Also probably depends on your soil type and if you have any roots or rocks you have to drill through
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,314
824
under a rock
I don't think your gonna have any luck running an auger off a BX hyd.
the first big egg you hit will stop it dead or break something.
probably need Hi-Flow
better off with 3pt.
but thats not an easy swap with the BX23S
the backhoe and mounting plates need to come off / mount your 3 pt. then mount the auger.
big hassle.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,075
999
Amsterdam, NY
I thought the BT603 BH had a flow of 6.6 GPM at 2,200 psi.
That is at the lower range of most PHD's so yeah the RPM's would also be at the lower range as well.
Old Machinist
May 27, 2024
714
831
NE FL
My LX3310 is rated at 5 GPM. Both the sickle bar and auger I bought for a mini ex were rated at 8 to 15. Like I said, the sickle bar works fine but I didn't try the auger. The hose fittings are some oddball sizes but I had them cut off and some JIC fittings installed on the hoses that came with them.
When I hit something too large for the sickle bar to cut it binds. I just have to hit the reverse button and back off. I imagine the same will go for the auger if it hangs up.
GreenBarnAcres
BX23S
Jul 30, 2024
E3B 2X6
Hi there,
Thank you, All, for your responses.
I had a 3-point auger, the Red Rocket sold at Princess. It worked ok, even in our sandy soil filled with layers upon layers of stone, until the boom connection to the tractor broke. After just 27 holes.
7,004
I got chinesium version for my mini. It works great. Flow rate required for it is 8-16 gal/min. My mini aux circuit flows just shy of 13 gal/min. I do have to reduce the flow rate significantly when running the auger. Full flow is WAY too fast.
You find them all over FB Marketplace for several hundred $. Maybe look for a small version and give it a try. Not sure what your flow rate is on your machine. Biggest cost for me was having the quick coupler fabricated.
