Maybe a new BX2380 ?
5,756
If you're planning on smashing thru woods with a BX, better plan on getting yourself a set of full skid plates. Otherwise, you're in for a world of hurt replacing HST fans. BX machines have very limited ground clearance with short tires. They are not designed for woods work.
Good point. I have under armor on mine when needed. Ground clearance is still an issue sometimes.
I've had a BX2360 for 8+ years.
I've shopped B's 2 or 3 times since.
If I had it to do over, I would have gotten a B of some sort to begin with. Now, an LX would also be in the mix.
Since I mow (MMM/mid-mount mower) and use a front snowblower, an L01 is not in the cards, as they don't have mid-PTO.
Still have the BX and really like it. Been a great machine.
There's times where it's just not quite enough....
3,809
I had a BX23 for a dozen years and worked the bejesus out of it. They are great little machines and pretty tough. The exception is the underbelly. I did have to replace my HST fan once, and that was with a set of Brotech skid plates. A stick still found its way up into the HST fan.
Anyone need an old fireplace?
B737
LX3310
Jun 9, 2019
2,024
2,201
did someone say BX fan replacement? so much fun!! :ROFLMAO:
