Burt
I decided to mark things real clearly on our tractor for my wife and even for me so I just don't forget. For instance, for me, it is difficult to tell the difference between a 3/4" bolt and a 19MM bolt. Since all the Kubota fasteners are metric, I just marked each or by the area what it is, that way, if I need to know it is at the point of use.
Then, I put reminders for greasing the loader arms in plain sight like they do for oil changes on your car. I also put similar reminders by stuff that my wife may not know or remember, like the 3 point lowering speed. At every point of use, I made some indication of what is used or needed. I even marked the valve stems with 30 PSI. It's difficult to read tires upside down covered in mud or dust.
I wrote down the date of the oil change and next due on the engine oil filter.
Kind of overdoing it, I know but it does help SWMBO "She Who Must Be Obeyed," to find stuff and use the tractor.
Burt
Burt
