making pellets
Tooljunkie
May 13, 2014
4,150
I have been reading about indoor pellet storage. Not much hard evidence regarding deaths from pellets off-gassing.
I know of one guy has a bin for bulk pellets,pretty sure hes still kickin.
I usually carry a ton into basement in fall before it gets too cold.
Now there is some smell, and it doesent seem to bother anybody.
My house isnt perfectly air tight, so im not concerned, but have a CO detector downstairs in case of a chimney leak.
NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
Nov 28, 2015
424
Pennsyltucky
I have an old coal room in my basement I converted for pellet storage. I keep 4 tons stacked on skids. I have a CO detector in the area with no issues. I kinda like the smell...
I use New England wood pellet. I can push it to 3 ton without cleaning. I tried a Lowes version which was cheap. So much ash I had to clean the stove every ton.
hassan
Banned
Sep 20, 2016
kushtia
Every year, 28,000 to 35,000 individuals in the United States are sickened by unintentional carbon monoxide poisoning and roughly 500 individuals pass away, numerous in their own house. Carbon monoxide is colorless, odor-free, and unsavory. It can not be found by human beings without the assistance of a detector.
A brand-new research study, launched today in the Journal of the American Medical Association (JAMA), has actually discovered that carbon monoxide quickly travels through plaster wallboard (likewise called drywall), the product utilized to complete walls and ceilings in the majority of domestic houses. The permeable product not does anything to stop the gas from permeating through.
Here's where the issue worsens: Twenty-five states need that locals have a carbon monoxide alarm in their houses however in December 2012, 10 states excused homes that do not have an internal carbon monoxide-producing source, such as a gas range or fireplace, or a connected garage where an automobile might be left idling. This relocation frets toxicologists who fear that these exemptions might provide individuals an incorrect complacency. It's thought that getting rid of the requirement for all the homes of have such alarms will cause an increased variety of unexpected carbon monoxide poisonings, especially in multi-unit structures.
In 2002, a North Carolina regulation in Oldenburg County needed carbon monoxide alarms in many houses, however all-electric houses (multi-unit and single) without connected garages were exempt. There were likewise no constraints on the kinds of alarm utilized, a lot of utilized gadgets that run by electrical power just.
According to a report by the Centers of Disease Control (CDC), there were 124 reported cases of symptomatic carbon monoxide poisoning over the following 9 days. Throughout power failures, individuals are more most likely to utilize carbon-monoxide-producing heating and cooking devices as well as generators that might be located close to vents, which can draw gas into the house.
3,578
If that is in any way true,, Its one way to clean out the gene pool
5,923
I always have a bit of skepticism when the first post is a copy/paste of a matter not dealing with the a kubota tractor.
I hope it's just me and Hassan comes back with something mechanical!
Tooljunkie
May 13, 2014
4,150
Facts are facts, but not one word is relevant to pellet storage.
In my line of work i am well aware of carbon monoxide (poisonoing) as i have been exposed to pretty high levels a while back at a previous place of work.
When i started doing more work at home i installed a port in my shop door and got an exhaust hose.
3,578
Sad part is common sense is a thing of the past. People that think they know more than they do!
5,923
Another thing my mom use to say, "If you half as smart as you think you are, you'd be twice as smart as you really are!"
Kinda kept ya humble, and aware there's more to the world then you know now.
7,238
The commenter Hassan, on the "ad post" was from Bangladesh and I killed the ad portion. :p
6,936
Back to the carbon monoxide just for a second :p Most people install them with there smoke detectors. Thats a big mistake, and is actually the wrong location for them :eek:
Carbon monoxide is more dense and hangs low in a room. The highest concentrations are at floor level. So the detector actually needs to be installed at bed height or electrical outlet height. If installed on the ceiling, your goose would be cooked before the detector went off ;)
3,578
Hey Bud hows the machine working? You should be kneed deep in them things by now :D
Tooljunkie
May 13, 2014
4,150
Been dang busy. Have some dry stuff ready, just need some free time in shop to setup and do another run. I did discover the componding moisture problem-as it heats up moisture is released and raw material absorbs it, so all i can do is keep feed rate constant so wood chips dont build up in hopper. Really want to get to it, hoping one day this long weekend.
3,578
So your saying the raw material is absorbing the moisture from the pellets as you form them? Maybe some kind of exaust fan would help draw it off along with the fine dust,, I dunno just a thought
Tooljunkie
May 13, 2014
4,150
If i fill hopper and stop machine as pellets quit coming out as they should, the material in hopper is soaked. Even when moisture is down around 10%. So the feeder i built should provide the material at a rate that will keep enough material flowing and prevent steam from building up moisture.
5,923
Maybe you need a propane fired heater blowing across your process, like they do at the grain elevator when storing grain to dry it.
3,578
OK Frank I see what your saying, I guess when they get squished theres enough heat to drive off a lot of moisture in the the feed. BUT knowing you, it wont take long to figure out how to fix it ;)
