I will make this as short as possible--
I have had four hydro lines replaced on this unit to date, and have had no luck in talking to Kubota in Columbus OH.
I was told by the rep from Ohio that he was going to have my dealer cut the line on the straight away, piece it together with a rubber hose, hose clamp it, & braze the crack. He feels this is being caused by the "harmonics & vibration" of the tractor, and that this should cure it.
The mechanic stated that the damage to the inside of the hydro unit would be simply minimal
Too many problems to list thru-ought the time I've had it. But, I will say--"IF" the tractor were prepped correctly, many would probably been avoided.
Does anybody here know how to get the chain of command name list for California's main office @ Kubota? Also, the same for Ohio?
The videos are online, and yes, I do wish I would have used photobucket, but it was so late in the night I forgot all about them.
Please view in reverse order. That is, from bottom up, as it will make more sense. Click on the "continue to video" and it will take you directly to the video I posted.
To go to video(s), please click here
Sincerely,
Chris
Sincerely,
Chris
