M95S air conditioning clutch not engaging
Lug66
LX2610HSDC, Z422KWT
Jun 7, 2023
116
67
SW Michigan
I don't know your system, but some systems can be checked with the key in the run position and turning the ac system on. You can verify clutch by applying (jumper wires) electronical power to the clutch. I would check the freon level first. Low or no freon will result in no clutch engagement.
Cherokee111
2006 Kubota M95S
Mar 31, 2022
Oklahoma
CHECKED THE LOW & HIGH PORTS BY DEPRESSING TIRE LIKE VALVE STEMS - BOTH MADE HISSING SOUNDS. WOULD CONNECTING AN R134A FREON KIT WITH GUAGE WITH SYSTEM OFF CAUSE THE KIT GUAGE TO REGISTER IF FREON IN CHARGED ZONE (I.E. YELLOW ZONE, BLUE ZONE, ETC). Does one alligator clip hot wire to the jumper plug in on compressor to get the clutch to engage? Also the clutch plate has no resistance when turned -- could removing clutch plate and spacers and reinstall to get manual resistance results possibly solve clutch engagement issue? Thanks
Tughill Tom
B3200
Dec 23, 2013
1,213
1,333
Turin, NY
Most likely it charge related. If you don't know how to work on an AC system CALL SOMEONE WHO DOES! You'll save money in the long run. Don't press on the TIRE LIKE VALVES AGAIN......... un-good for system.
Fedup
242
69
Winchester
I fully agree. It can't cost that much to get someone to look at it that knows air conditioning.
What's been "checked" so far proves nothing. In order to check something, you need to first know something about it.
4,891
this....
...is a GREAT way to require the purchase of a new PTO clutch !!!!
ALL electric PTO units have their clutches 'spaced' within 3-5 thou.
You can power the clutch coil with a jumper to +12 and should hear it 'clunk' when energized. As a reference a typical riding mower EPTO coil will draw about 4 amps of current when energized. Hopefully the WSM will say what yours draws. If not current, then resistance, like 3 ohms ,+ or -.
