Hi
I'm a new member and this is my first post. I'm replacing the clutch in a M7500DT. I bought a aftermarket clutch part number 35555-25100. This tractor has a pto clutch disc that goes up against the flywheel and is operated by a hand lever. The transmission clutch disc is captive in the pressure plate. The problem I have is, the back of the clutch finger that releases the transmission clutch are only about 1/8"-3/16" away from the clutch disc. They seem way too close to the disc for proper disengagement without hitting the disc. If anyone has experience with this clutch or knows the adjustment specs and procedure, I would appreciate any information. I'm not comfortable putting the tractor back together this way. The vender I bought it from insists that it will work, but I would like to verify the finger height before I put it back together. It looks like this clutch was used on multiple M series tractors in the early 80's.
Thank You
Christian
Thank You
Christian
