Hello everyone. I am new to your forum and I purchased a used Kubota recently and apparently inherited a wiring issue. The unit continually blows the 5 amp fuse for the dash panel cluster and when replaced, it will flash ERROR - 99 on the display. The unit is alerting me with the lights that a parked regen is required, however, with unit in neutral, parking brake engaged, and tractor at idle, I can press the button to initiate the regen and the computer will begin to raise the RPMs slightly, but then fall back down as the error code above is flashing and a loud beep sounds each time the light flashes. I have used higher amperage fuses in the slot to see if it would maintain long enough to regen, but that hasn't worked. The panel stays illuminated, but the error code is flashing continuously. I have tried operating at a higher RPM under load in hopes a passive regen would be initiated, but no luck there either. Any help would be greatly appreciated. Thank you in advance.
