M7060 code 12
Al38kit
M7060
May 20, 2026
texas
I'm new to the group and have searched for the above problem and found one link that doesn't answer my question.
Code 12 showed up while working a couple weeks ago.
It appears to be related to the 4WD solenoid or wiring.
I can't find the wiring and solenoid, I have a cab and what directions I've found point to the left side of the tractor just forward of the axle, but I can't see anything there.
Ideas?
Thanks,
Ak
6,997
Ideas?
Thanks,
Ak
Maybe buy this and do some reading?
11,753
That appears to be the PTO valve...not 4WD....Although it does look like the connector has pins for both...I'm just no sure where this valve is located...I'm trying to find it.
I did find the download for the manual...thank you.
@Bee-Positive showed the Solenoid Valve Assembly which houses among other things the 4WD solenoid valve. It's located on the left side of the tractor inside the rear wheel well.
You might even need to remove the fuel tank to get to it. It's buried for sure and won't be a fun job.
Al38kit
M7060
May 20, 2026
texas
I think I found it...IF I could get the connector off, I may be able to ring out the wires, but it is in a really nasty spot...
I think you're right regarding probably having to remove the fuel tank.
Thank you for the information.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
878
856
Amsterdam, NY
READY-SHOOT-AIM - hey, that's my M.O. you're copying there!!! :ROFLMAO:
#8 in the diagram is the 4WD solenoid valve.
As TheOldHokie said do some reading.
Page 2-M20 of the WSM also has a good diagram of how it works.
Good luck, hope it's an easy fix.
Al38kit
M7060
May 20, 2026
texas
I found the electrical schematic and since the connector is such a pain to get to, I think I'll initially trouble shoot it from the electric 4WD SW.
This, of course, means nothing if there is a connector problem etc, but I can at least confirm that it's getting the bus voltage to the wire and I there is 10-12 ohms to ground, the coil should be good...
Hope I don't have to pull the fuel tank.
As a wise man once told me, this problem, when solved, will be simple.
Thanks again.
11,753
I took a look at my M6060 yesterday, and if I ever had to get to the solenoid valve assembly I'd need to remove the left rear wheel, fuel tank and probably the step too. Access is near impossible otherwise.
I think part of the solution needs to be resigning oneself to certain aspects of the job. I've often found that it's those times when I try to cut corners that the frustration sets in and the job typically takes so much longer. Ultimately we often end up doing it the right way but only after trying to do it by taking shortcuts that rarely turn out to be time savers.
I have Rim Guard and three sets of wheel weights on each rear wheel so it's no fun getting the wheel off. Removing the fuel tank doesn't look too bad, and doing it when the tank is close to empty would be the smart move, unless you want to drain the tank.
Al38kit
M7060
May 20, 2026
texas
I agree completely.
I tried to troubleshoot it as much as I could from the switch. It is powered and shows bus voltage and the SW works and has a good ground.
The odd thing is that the resistance to the coil is about 400 ohms...so I don't yet know why the resistance is high.
I haven't got to the plug with four conductors...I expect the next thing is to pull the wheel and tank...I just don't have time to do it right now and I can get stuff done in 2WD....
I'm probably stating the obvious, but it's got to be a bad wire, connection, or bad solenoid. I'm not up for spending the $800 bucks or whatever on the solenoid yet.
Always something.
Al38kit
M7060
May 20, 2026
texas
Today's report from the trenches:
Through no small feat I was able to remove the connector and test it.
No voltage at pin 1.
The switch 4WD works and powers the white/blue wire, but I cannot find continuity to the solenoid connector. That set of wires appears to run on top of the transmission housing and go forward.
I have taken the floor panel out and and checked four connectors to try to establish continuity to the switch and connector and have been unsuccessful....
Ideas on wire routing etc?
11,753
So the W/L (white/blue) wire changes to W/G (white/green). Is the wire going to pin 1 of the solenoid valve connector white/green? The is where you confirmed no voltage when the 4WD switch is in the on position.
Al38kit
M7060
May 20, 2026
texas
Yes to both.
There is a diode block where the brake switch enters into the equation and I believe that’s where the wire changes colour but I’m not positive.
The wire from the valve goes forward along the transmission and I may have to pull the fuel tank to trace any of that. It’s really hard to figure out how it gets to the switch and I am not above running a direct wire to the connector and energising the solenoid in that manner.
Al38kit
M7060
May 20, 2026
texas
As I'm trying to track down what is probably a broken wire, I'm interested in what sends the fault code 12.
The tractor throws the code for both the application of brakes and also the 4WD switch actuation. As the input to the ECU is downstream of the diode pack, I would expect that the wiring is fine up to that point.
Does anyone know how the tractor knows when the power is applied to the solenoid, that the 4WD is not active?
As I'm physically trying to find the wire upstream of the solenoid connector, the problem is most likely between that and the diode pack, which I have not yet found...It is probably closer to the brake pedal than it is to the 4WD switch.
11,753
I would think that the ECU is looking for a known current range through the Y/B wire, and when that range is out of spec a code is triggered. :unsure: When the 4WD solenoid is energized a known current is flowing through the W/G wire and the Y/B wire. If the solenoid fails, the current in the Y/B wire changes and the ECU would do an "uh oh" and trigger a code.
With the 4WD switch off there's no current, and with the 4WD switch on there should be a known current. I might be wrong but that would make sense to my non electrical engineering brain.
Al38kit
M7060
May 20, 2026
texas
It appears I have found the problem...The machine is stuck in 4WD.
I removed the floor pan and found a few wire bundles and in the one just left of the mid line there is a large connector with a white green wire.
I cut the wire and on the distal end from the switch, it shows 12 ohms.
The other end of the wire that I cut is connected to the 4WD switch somehow and shows bus voltage.
When power is applied to the circuit, it shows the green 4WD symbol and no fault.
When power is removed, it shows the green 4WD symbol and code 12 fault.
In short, the green 4WD symbol is always on...when the 4WD switch is on, operations are normal.
I am going to put it back together and get mowing...I have a heavy mower on the 3 PT and I'd rather be
stuck in 4WD and get some work done rather than fix it now.
Just a follow up in the event that this happens to someone else.
11,753
Looking at the WSM I noticed this interesting bit of information. Depressing both brake pedals engages 4WD.
2-wheel drive (4WD switch is turned to "OFF")
• When both brake pedals are depressed together while driving in 2WD mode, 2-brake switches operate the 4WD solenoid valve and activate to the 4WD mode. 4WD mode activate the 4WD braking system and the 4WD indicator lights up.
Al38kit
M7060
May 20, 2026
texas
Yes.
That gives another input to the valve. It is diode protected from feeding the pto, etc.
This is a bit more complicated than I had expected, but if I run with the SW in 4WD there are no codes present. I need to reconnect a wire today and ops check this.
It has been interesting.
Thanks for your input.
