M7040HDC Stays in 4WD
wmwbutler
Kubota M7040HDC
Sep 8, 2020
Georgia
I have a 2012 M7040HDC. The 4WD lever operates fine and all indications are that it is out of 4WD, but it never disengages. I use the loader to lift up the front wheels and they don't turn freely. I can get one to turn and it rotates the other tire in the opposite direction with alot of resistance. I have looked at the linkage and don't see anything bent or worn.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,235
1,018
Williamstown Ontario Canada
I am with tthorkill thinking it is the limited slip in the front dif..
I will be at my 2012 M7040 tomorrow and will try what you are doing.
Dave
wmwbutler
Kubota M7040HDC
Sep 8, 2020
Georgia
Dave
If I pick up the front wheels with the loader and drive in reverse, both wheels turn.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,199
128
Coyote Flats,Texas
Have you checked MFWD linkage to be sure it's still connected correctly. Have you tried driving in reverse a little distance after pushing MFWD control handle down?
wmwbutler
Kubota M7040HDC
Sep 8, 2020
Georgia
Yes. I have check all the linkage and it is fine. It operates as it should freely. I have drive in reverse with tires on ground and raised.
wmwbutler
Kubota M7040HDC
Sep 8, 2020
Georgia
I sprayed everything with pb blast hoping that it will help, but it didn't. Everything looks normal and shift normal, but it still has the front locked in 4wd.
Tx Jim
Apr 30, 2013
1,199
128
Coyote Flats,Texas
Have you checked to be sure pin(key 70) & bolt(key 40) are present? I', not even sure I have a clue what task bolt(key 40) performs but Messicks shows to stock that part & key 30
