M7040
Stevelippe
Oceanside
I have an M7040 that I maintain and it has a problem with the return system. Every once in a while the hose off injection pump blows from too much pressure. I know the return system doesn't have more than fuel pump pressure. Any one else having this problem. My concern is that there is some high pressure leakage from injection pump causing problem. Not sure how to test.
9,160
It's more likely that it's got a clogged return line or fitting on the fuel tank or a clogged vent on the tank will also cause issues.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,254
161
Coyote Flats,Texas
Welcome to OTT
I once during cold weather experienced the fuel return line separate at connector on my '11 M7040. I rejoined the hoses & it's been fine every since. The fuel return line on my M7040 has a "round check valve" installed that I don't see in parts schematics
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,254
161
Coyote Flats,Texas
NIW
Can you please explain the need for check valve in fuel return line on a Kubota? I've never noticed a check valve on fuel return line on any other brand tractor I've been associated with. I know my JD & Ford tractors don't have a similar type check valve on return line.
Thanks,Jim
