M6800DT hydraulic lift problems
farmer98
M6800DT
Sep 4, 2013
Mount Vernon, MO
Problems with 3 point hydraulic lift: the position control lift lever has become quite stiff when trying to alter its position and the maximum lift height seems to be less than normal. Additional pertinent info: the front end loader hydraulic works fine and the dip stick for the hydraulic oil level reads in the low but acceptable range. Any ideas? Thanks for the input.
4x4man514
2004 m6800 4x4 open cab fel
Jul 5, 2019
augusta ga
did you ever figure this out? im having the same problem. I know my fluid is low I haven't had a chance to top it off but this feels like a linkage issue. if I pull any harder im afraid ill bend the linkage. like it needs lubing but I don't see any grease fittings.
thanks!
