M6800 starts and shuts off repeatedly
golstho
M6800
Mar 10, 2025
17
Alabama
I have searched the forum and have found several posts about similar issues, but none that are exactly the same as mine. M6800 4x4 with cab and loader. When starting the tractor the tractor will start when the key is in the start position and die when the key is returned to run. It will do this 4 or 5 times. after 4 or 5 times of this the tractor will start and run fine, until you shut it off and then the process starts over again. If i hold they key in start during this it will continue to run but die when key is returned to run. no amount of fiddling with the key or throttle input changes the process, it always takes 4 or 5 times maybe 2 or 3 occasionally after the tractor run for a while. i have checked and the vents are not clogged, changed fuel filter, previous owner replaced shut off solenoid a while back but that didn't fix it (not opposed to buying another to try). tractor has been like this for a good while and i cant seem to figure it out.
5,680
curious, so looked at parts drawings. seems to have a mechanical 'lift ' pump. If it's worn out, could cause the problem ??
golstho
M6800
Mar 10, 2025
17
Alabama
it does have a small mechanical lift pump i have not changed it and to my knowledge the previous owner didn't either. tractor has 740 hours so i guess it could be toast
2,043
Sounds like the run solenoid (or stop solenoid) is not being able to hold the fuel open when the key returns to run.
Research what solenoid is near the injection pump and how it operates and see if it is working correctly or not.
golstho
M6800
Mar 10, 2025
17
Alabama
when the solenoid is removed it seems to work properly, but i am wondering if somehow it works when removed but not installed (don't know if that is even possible). been reading about a time relay in the dash possible being the problem but not sure how i would diagnose that part.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,235
1,845
WestTn/NoMs
I don't have access to a WSM for your rig, but it probably has the dual coil fuel solenoid with pull-in and run coils. It has all the symptoms of run coil drop-out. You say the solenoid has been replaced, so it is probably ok. You could have a bad connection or key switch. Clip a test bulb on the run coil and watch it. Even a momentary blink when the engine dies indicates a power drop, and it won't pull back in.
8,731
M6800 can have 2 different electrical systems and they affect the key stop relay and solenoid differently.
The stop solenoid has 2 coils internally one coil for pull in and one coil for hold.
sounds like the pull in coil is working but not the hold coil.
The issue may or may not be the actual solenoid it could be the solenoid relay or a wiring issue.
Give me the serial number and I can narrow it down on what to look at and where tolook for voltage or not.
golstho
M6800
Mar 10, 2025
17
Alabama
Serial # 70199
golstho
M6800
Mar 10, 2025
17
Alabama
Just unplugged solenoid wires and tested with meter. Battery voltage 12.5v. both wires are red with white stripe one is larger than other. Both test exactly the same around 9.8v when cranking over the engine, then jump up to 12v when key is returned to run, they stay at 12v till the timer in dash clicks and then drop to nothing.
8,731
Well that's not right...
You should not have voltage on both all the time.
Remove the solenoid and see if it will start and run.
golstho
M6800
Mar 10, 2025
17
Alabama
Also while out I tested the solenoid again and it doesn't always function properly. On start it pulls in Everytime, but when key is released to run sometimes it stays in until the timer goes off and sometimes it pops out as soon as they key goes to run. Also looks like the wires have been spliced before using crimp connectors. I would like to remove these and solder in but not there is not much wire to work with and can't really get behind engine.
8,731
So we're on the right track.
Right now it could be the relay, main switch or the solenoid itself.
Is it a new solenoid?
Let me study the wiring path a little later and I'll tell you where to check next.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
668
277
Herald Calif.
I take care of quite a few M6200, M8200 and M9000. I have replaced the key switches on almost all of them. I keep an extra in my service truck.
golstho
M6800
Mar 10, 2025
17
Alabama
its not a new solenoid though i may need to buy one. i finally got around to removing the crimp connectors and soldering/heat shrinking the wires together and the solenoid worked perfect and the tractor cranked like its supposed to crank. thought i had fixed the issue but it only worked for a few cranks and now its right back to doing the same thing. looks like i am going to need to replace the solenoid, switch, relay, or something else
12251hd
M6800, L35, RTV
Nov 23, 2018
62
Woodbridge, VA
Golstho, did you ever find the solution to your problem? My 6800 has shown similar symptoms on initial start, and I'd like to find out what your fix was. Thanks.
golstho
M6800
Mar 10, 2025
17
Alabama
No I have not solved the problem yet. Still takes 2 or 3 tries to start on first start and after that starts fine. Fuel shut of solenoid didn't fix the issue. Another poster suggested ignition switch. I am going to replace that next.
golstho
M6800
Mar 10, 2025
17
Alabama
will do! i hate to keep throwing parts at it until i find the right one as there are so many things it could be (switch, relays, timer, etc.). local dealership thinks it could be the oil pressure switch. i discovered yesterday that on the initial start that i can keep it running by keeping the starter engaged and by holding the key between start and run but at soon as the key returns to run it shuts off.
