3 Point lift WAS working fine. Parked tractor in barn for like 2 weeks and now it will not lift. Had no issues prior to this. Fluid level is full, Changed filters about 3 months ago. I seldom use this tractor, mostly for moving round bales of hay.
With both 3 point control levers in the up position it will not do anything, but if I lift manually the hay spear that is attached it will hold arms to the height that i lift them, and will not go down, until i move the lever to the down position. If i move the lever back to the up position while it is coming down, it will stop but not go up. Down speed control knob under and in front of seat is totally open.
Does anyone have any ideas what might be wrong here?? Seems like a valve is not working, but i CAN stop the down movement. This tractor only has about 200 hours on it.
Thank you,
Thank you,
