m5660 three point hitch will not go up
Pau7220
Aug 1, 2017
785
278
Scranton, PA
First thing to do is disconnect, clean, and reconnect the loader quick connects. One may not be seated properly.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,199
128
Coyote Flats,Texas
To my knowledge all tractor 3 pt arms can be raised by hand with no load attached if the 3 pt doesn't have rare option of "down pressure". How long since hyd filters were changed? Does frt end loader operate correctly?
mikester
M59 TLB
Oct 21, 2017
3,547
2,006
www.divergentstuff.ca
If you have remotes or a diverter valve on the tractor and one of them is activated it can stop the 3PH from lifting. Check that something isn't partially activated.
SidecarFlip
Banned
555
I can lift them manually they will not stay up
The knob under the seat does slow down the rate a little
It should stop them from lowering altogether of it's closed (right turn fully).
6,363
Not if he's manually lifting the three point arms, the only reason they are falling slowly is ????? maybe resistance of the seals on the rock shaft??? As the piston didn't move, so no fluid to stop the piston, that wasn't moved anyways. :p
MtnViewRanch
796
233
Lakeside Ca.
I'm lost, the title says the 3pt won't go up, but everyone is talking about the hitch going down.:confused:
First thing that comes to my mind is be sure that your draft control lever is all the way forward-down. Then use the position control to operate the 3pt hitch.
Good luck. ;)
5,205
1,889
Had one somewhat recently same issue. Won't go up. Found draft control pivot link broken, caused position control valve to "think" that the draft control was all the way, forcing 3ph to bypass fluid so that it wouldn't build pressure. Replaced broken link, problem solved. That particular one happened due to a user backing a large (8') single spindle shredder into a ditch with a lot more force than it's designed for.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,410
1,691
Kalamazoo, MI
Interesting stuff. I wasn't aware that the M5660 has both the position and draft control for the 3 PH. The specifications on Kubota's website shows position only.
Is this an older tractor or is there simply a typo on the Kubota specifications?
