I have an M5400 that had weak hydraulics. Both the 3 point and the loader are weak but power steering is good. The hydraulic fluid had water in it so I changed the fluid and filters with no change. I took out the safety valve and cleaned it with no change. I took the hydraulic pump apart and resealed it and engine started filling with hydraulic fluid. I changed the pump head seal and started the tractor and again the engine filled with hydraulic fluid. Could the safety valve fail and cause overpressure and blow the pump seal?
