m5140 - would like to add front 3 function for grapple - lots of ?'s
6,062
I have read enough and will go to kubota dealer maybe Monday. I can’t find a part number for the “kit” for 3rd function so I’m going to price it and use the info they offer. If i can’t beat their price then i will just scrounge up my penny’s - they say buy once cry once and my dad says it’s nothing but paper😂. I appreciate you fellas input on my problem ! I do plan on installing myself so i may create a new post soon on install help.
The kit is a "whole goods" package for the LA1153 loader.
Option # M1867 for ROPS machines
Option # M1977 for cabbed machines
Messicks lists both at $1021.
smgchandler
m5140 and zd1211
Feb 5, 2025
12
garrett0529
Old hokie i sure do appreciate that info ! Not sure why but when searching googling it’s hard to find ! Do you think Messicks is the place to buy ? M1867 ? Not sure on what the “whole goods” is but if i can get the grapple going with efficient protected lines and control from the bucket stick then that sounds like the route i want to go. And 1k is looking cheap ! Shame i got grapple for 1500. And connections will be 1k but i see me using grapple for myself a lot down the road. As pappy says it’s nothing but paper ! Thanks for the info
smgchandler
m5140 and zd1211
Feb 5, 2025
12
garrett0529
So kit should be everything i need except the couplers ? I have not looked at what the kit includes but will research and will probably seek more info. Will post shortly. Thanks for the info
2,541
Not sure on what the “whole goods” is ….
Whole goods is through the sales department at a dealership and not the parts department. They are generally a complete kit to be added onto a tractor at purchase or after purchase.
They are usually priced much lower than the individual parts. For example a rim with a tire mounted is cheaper through whole goods than an individual tire through parts.
6,062
"Whole goods" are implements and packaged options as opposed to "parts". The parts department does not handle whole goods sales. You need to speak with a salesperson as to what is included ln that package. I am reasonably sure its not everything shown on the parts diagram.
10,012
The factory 3rd function kit for my M6060 with part number M7992 cost me $1,708 installed by the local dealer back in 2022. I bought the tractor off the lot in Sheridan and it would have been considerably cheaper had I ordered the tractor and added the 3rd function to the order. In comparison, when I ordered the MX in 2021 with 3rd function it was $1,300 installed. So $1,021 for the kit for your tractor seems very reasonable.
You could ask a salesperson at you local Kubota dealer what the cost would be for the kit, but I doubt it'll be any cheaper. For current tractor models, you only have to use the Build My Kubota feature on Kubota's website to see what the option costs when ordered through sales. I upgraded my M6060 to rear wiper and rear defrost (three pieces of glass) which comes with a more powerful alternator and swiches for the cab and it was a little over a $1k through sales, but would have been over $5k through parts.
6,062
Fellas i have to ask this ! Huge difference in price ! Anything wrong with WR Long ? The Kubota dealer sells them !
How huge - $600 vs $1000?
As stated early on the only real difference is cosmetic.
The OEM kit MAY be a little cleaner looking but functionally they all do the same thing using the same basic valve and joystick button control. In your case Kubota also offers a hydraulic SSQA latching option (more plumbing and more money) that leverages the third function plumbing.
smgchandler
m5140 and zd1211
Feb 5, 2025
12
garrett0529
Well not that huge ! 1200. Installed with the wr long and 1250 for the kubota and i install plus if i want the different connectors with the kubota then 250 more. The grapple has the flat end connections (newer style i assume). I can change those and wont need but will still have to buy two old style to go on grapple hoses
smgchandler
m5140 and zd1211
Feb 5, 2025
12
garrett0529
I believe i can install - i need to find the right hose to disconnect (green) and figure out where to pull power from for the switch. The only advantage with the kubota kit is it has two short metal lines where the wr long is just hose. Plus I’m sure i can’t talk kubota dealer into coming to house to install. Will have to haul tractor to them - not a big deal but it will be two trips !
6,062
Why are you hung up on couplers? Many people would tell you to put flat face couplers on the tractor side. Cost wise thats probably a break even choice.
I think this is becoming an exercise in paralysis by over analysis.
