M5040 Tractor Shifting problem
LRochelle
dugspur VA USA
My 2007 5040 was running fine I pulled in the drive let sit for 30 minutes returning to tractor went into reverse no problem then when I attempted to shift into forward it would not go into forward or reverse. I found that with the gear shift in neutral I could shift the forward and reverse lever with no problem but with the lever in forward or reverse I could not shift the gear shift lever or with the gear lever in gear I cannot shift the forward or reverse lever all of this with the engine running but I turn off the engine everything shifts correctly. Can someone help out please?
gpreuss
Oct 9, 2011
1,166
Spokane, WA
It sounds like your clutch is not completely disengaging.
LRochelle
dugspur VA USA
Thank you I will try clutch adjustment I adjusted it all the way out I will try going in with it and if you have any other suggestions I would appreciate it..
6,992
It has a linkage or cable problem.
The shifter on these uses a cable and rod at the same time, one out of adjustment, disconnected or broken will do exactly what you state.
If you tell me the exact model I might be able to point you where to look.
6,992
Sorry need a little more info to go on, there are just too many sub models to narrow it down.
The serial # will tell you/ us what model and sub model it is.
