Hi all.
I'm also a new Aussie member so this is my first post on this forum.
I have a M4950DT with a FEL fitted. The tractor only has 1850 hours on it, which isn't much for a machine of it's age. For some reason diesel fuel is slowly leaking into the crankcase causing the level on the dipstick to rise quite significantly. I'm pretty sure it's diesel because the oil gets quite thin and it smells faintly of fuel.
I recently replaced the diesel lift pump (even though the diaphragm checked out OK) and changed the oil and filter/s. I thought this would fix the problem but after only 10-15 hours use I've noticed that the oil level has risen again slightly.
I'd really appreciate any thoughts or advice on this problem because I'm quite new to diesel engines and the diesel mechanics in my district don't seem to have much experience with Kubotas.
Thanks for the great forum, and for reading my post.
