LX3310 just died with no electrical power
fretwire
LX3310
Feb 29, 2024
WV
Was mowing with my MMM and without any dash warning the tractor shutdown. LCD dash display went completely blank. Of course it will not restart in this condition. I can turn the ignition to the "ON" position but the LCD stays blank, nor do any indicator lights come on. Also, the headlights or emergency flashers do not work with ignition "ON". I do hear the clicking when I turn the ignition ON though. Battery is fine (hooked up to my truck battery to test) and all fuses up front around the battery are good. Any ideas what to check next? It's a 2024 model.
Orangeglow
2015 BX2370
Jun 19, 2014
361
181
Prescott, Ontario
Make sure all levers are returned to normal so that all your safety start circuits are in the correct state to allow it to start. If that doesn,t work, I,m not sure how you proved your battery is fine by hooking it up to your truck battery to test it . Maybe you could explain more how you did that. Also, check both ends of your battery cables to make sure they are shiny clean, and tight.
9,624
A 2024 model will still be under warranty right? A call to your local dealer might be in order.
fretwire
LX3310
Feb 29, 2024
WV
Yeah, the safety circuits are my next plan of attack, but can a fault in the safety circuits cause the dash screen to be completely blank when the ignition is in the on position? Plus, no headlights or flashers either? As for the battery test, I just paralleled my truck battery with the tractor's using jumper cables.
fretwire
LX3310
Feb 29, 2024
WV
That's plan if I can't fix it in house. Otherwise I'll need to winch it up on my trailer and haul it 50 miles to the dealer... unless they make house calls.
2,423
Sounds like there is no power to the key switch and noted above are the probable reasons:
post #3 is (probably) pointing to a main fuse block
Battery cables need attention
Battery may be bad. (Eliminate the tractor battery from circuit and then attach truck battery to the tractor. Keep the tractor positive cable away from the metal parts of the tractor of course)
9,624
Any update on what you've found?
3,035
1,154
Hooking another battery up to the original battery with jumper cables does NOT test a battery. If the original battery has a dead cell or 2 it will suck up all the power coming from the jumper cables and you will still have no power to your key switch. The only way to test the battery is to hook up a Load Tester to it. Load Tester’s are pretty cheap devices.
fretwire
LX3310
Feb 29, 2024
WV
I checked what I could without tearing things apart. I misspoke in my OP, the emergency flashers did work but that's it. As I mentioned, turning the ignition ON gave me that chatter (fuel solenoid/glow plug circuit?) so I figured part of the ignition switch was OK. I did disconnect the battery and hooked up my truck battery...same thing, no dash screen or indicator lights. Dealer has it now and hope whatever it is will be covered by the warranty. Paid a lot of money for this tractor and having it fall on its face like this with less than a 100 hrs is disturbing.
2,871
Based on this info - I would look through all the safety switches again - the only other problem could be the wires from battery to starter and ground.
Did you bypass key at starter yet? ( I had a toro 3200 that would not start - no nothing ....... went to bypass key at starter, found that the starter was smoked - like toast!)
9,624
Unless the dealership finds that the issue was caused by neglect, abuse, rodents etc., you'll be covered. The two year warranty covers everything accept the issues mentioned above. If you have KTAC then even things caused by abuse or neglect can be covered.
I hope it's something easy to fix and that you're back up and running in no time. I'm on Kubota #3 and #4 and have had nothing but a positive experience with Kubota products over the past 10+ years which includes a BX, two MXs, an M and a generator.
