LX3310 E-21 Error Code
awilkinson
LX3310 4wd w/ Cab
Jan 13, 2024
Eastern Oregon
I believe it is caused by a faulty ground or other wire connection, it started after snow blowing for about an hour and a half, so I think vibration caused a loose connection. Where is the ECU located in the lx3310 w/ a cab? Also, when I do get it started the throttle acts weird unless I disconnect the battery while it is running. My dealer advised me it could be a the battery since it is -15deg F here and the thing was slow cranking. So I purchased a new battery and it cranks and starts now. (awesome) but wont throttle up correctly. So now after some research I believe wiring could be the cause. If someone has had to troubleshoot E-21 where are the connections I need to look at?
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
My manual for the LX3310 indicates that the E-21 code is caused by a lack of communication with the engine and recommends refreshing the software in the ecu. 1705205522435.png
