Lug Bolts
3,552
Ok on my 2360 what sie are the lug bolts? 19mm is loose and 18 dont fit and the same with SAE,, soooooo is this information kripto or am I all screwed up???
Stumpy
L175
Dec 1, 2011
848
NE Ohio
There's nothing that makes any sense in between the two. 32nds size bolts are incredibly rare and there are no metric half sizes that big. How loose is the 19mm? 19mm (3/4in) is muuuuuch more common than an 18mm. I'd bet you've just got a slightly undersize lug and a loose socket. The tolerances on bolts, sockets, and wrenches can vary widely depending on quality and design (it's gotta slip over the bolt easily). You can measure it with a $10 set of hardware store calipers if it piques your interest.
3,552
Stumpy,, neather are so loose ( SNAP-ON & CRAFTSMAN old ones) that they would slip but when torqueing the lugs I kind would like to have one thats really close to the size of the bolt head,, maybe me just being anual
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Just checked mine since I was up here, no use to you but my fronts are 17mm and the rears 24mm. Both sockets fit well.
Hummm Snap-On is one of the highest quality tools in my experience, interesting. How much slop are you seeing? For example a Craftsman 1/2 drive 12mm 6pt impact socket on a 12mm bolt gives me less than 5 degrees of slop. A 13mm socket from the same set gives me over 15 degrees of slop on the same bolt.
I'm not sure what to tell you, I stand by my original statement, no other size makes sense in that range.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
If your not using a hex socket,they are more forgiving if a little slack.
Dave
