OK, one problem so far: low oil pressure when oil is hot.
V1902
I had thought the problem was the missing camshaft plug, so I took the gear case off and looked.
There is a plug in the end of the camshaft.
I looked really closely and the "plug" in the end of the camshaft is actually some kind of set screw that threads into the end of the camshaft. Parts books shows a set screw at the back end of the camshaft, but nothing at the front end.
So, why would the oil pressure drop when the engine is hot?
It's a new rebuild with new bearings and all parts within spec (according to machine shop).
I hooked up a mechanical gauge and the readings were about the same
When cold, mechanical gauge read about 5 psi higher than electronic gauge
When hot, the readings were about the same, with the mechanical gauge showing maybe 2 psi higher
I ran the engine for about 5 hours, varying between 1800 and 2400 rpm over that time, split over 3 days.
When engine is at running temp (180*F on water temp gauge and about 230*F on on the crank case and oil filter , using IR thermometer), oil pressure is low. like around 20 psi at 2400 rpm
Cold, right when starting: 50 psi
As temp goes up, oil pressure goes down.
oil is RotellaT 15W-40
Temp at the gauge and oil filter taken with IR thermometer
No change in oil level (increase or decrease)
psi,temp (IR thermometer on lower crankcase and oil filter)
49,135 F
41,140 F
40,170 F
20,240 F @ 2400 rpm
15,237 F @ 1800 rpm
10,230 F @ 1400 rpm
08,210 F @ 750 rpm (idle)
Started off at 1100 rpm until water temp reached 140
Then increased to 1800 until temp @ water temp gauge reached ~180
Then increased to 2400 rpm for 20 minutes
Then decreased to 1800 rpm for 5 minutes
Then decreased to 1400 rpm for 5 minutes
Then decreased to 750 rpm for 5 minutes (idle rpm)
Thanks
V1902
49,135 F
41,140 F
40,170 F
20,240 F @ 2400 rpm
15,237 F @ 1800 rpm
10,230 F @ 1400 rpm
Thanks
