L235, eng, DH1100. only 1200 hrs.
At idle cold, pressure is only 5psi, at 2000 rpm only 10 psi.
Manual lists possible causes. Restricted oil filter or screen, pressure relief valve stuck open, rod, main or cam bearings worn and worn oil pump.
All of these are major except oil fliter which has been changed.
Where is the oil pressure relief valve? The manual has a drawing of it but does not show where it is or how to ck it.
Cking the screen and rod bearings require removing the oil pan. The front driveshaft runs under it and I do not see how to remove it. The manual has nothing about removing the shaft.
Thanks in advance.
Thanks in advance.
