I'm new here, but I've owned Kubota equipment for quite a few years. My current problem is not with one of my tractors, but with the Beta/Kubota engine in my boat. The boat is an older mini-trawler, an Albin 27. I recently replaced the original Lehman/Peugeot engine with a 50 hp Kubota-based engine removed from a lifeboat.
The engine had less than 10 hrs on the clock when I got it, and has about 20 on it now. It runs great, it starts instantly, runs smooth, and has no worrying mechanical noises. The problem is that while it shows about 50 psi oil pressure cold, that drops down to about 15 psi when at operating temperature.
This is a V2203 engine (coincidentally, the same as in my L4310) and I've done a good bit of research -- I'm wondering if this could be the camshaft plug issue, or perhaps the relief valve? I would really appreciate any ideas I could get from this forum.
I can't work on the front of the engine as it is in the boat, but I can use my home-built gantry to hoist it up into the cockpit to give me access. I'd just like to have a little better idea of what I'm looking for though before I dive in to that step.
Thanks in advance,
Tom
Thanks in advance,
Tom
