lots of oil is spraying out breather
flh77hd1
B8200
Nov 17, 2013
Berkeley Springs, WV USA
Adam, not sure if you done this yet but i did mine. move the fuel filter out of the way, take the supply hose and the return hose off. Three bolts are very easy to take off it's a 12mm wrench. The top bolt isn't a bolt it's a stud with a 12mm nut on it. I took it off by double nutting the stud and backing it out. There is a bolt on the engine (bell housing) that you need to loosen up because the pump will not slide out unless you back that bolt out. Changing the seals on the pump isn't a big deal , just take your time and have patience. Good luck
