Had a comment on TBN about how my 3rd function lines were out to the side and exposed. I'm thinking Kubota should include 2 more quick release points on their QuickTach hydraulic connection thingie to include the 3rd function lines. I'll probably never disconnect any of them though. Never ever had the loaders off on any of the 3 JDs since 2004.
This thing is better than any of the 3 JDs I've had with (in addition to some noted above):
1. Guards to the valve stems.
2. Metal covering over the driveshaft (JDs only have plastic) (I gotta crawl underneath there and see what they have for Ujoints, maybe none, e.g. other kind?)
3. 3ph raises a tad higher
4. The fuel cap actually screws on and off easier. Recently would not take 2 gallons with 2.6 hours on it. Good sign.
5. The radiator overflow container is right in front and easy to get to. Needed a screwdriver to take the top off the one on the 2025R and a funnel with long snout to refill it. Then top was hard to put back on.
6. More room to get the end snorkel off the air cleaner.
7. The brake pedal lock snaps off by tapping the pedals. Hard to get off at times on the JDs.
8. Top link is really easy to turn, e.g. that grease point maybe. Actually smaller, too. Hoping the tilt one will be equally easy. Tilt was always hard to turn on all 3 JDs.
9. Three position steering wheel.
10. Of course, 3 range HST control. Only 2 on the JDs.
A couple negatives in addition to maybe a couple noted above):
1. Absolutely NOTHING on the FEL bucket to attach anything to. JDs at least had a couple detents on top to attach tension cords.
2. Cruise control seems almost impossible to use but seldom need it.
3. No settable/but bypassable on the 3ph control. There's a stop, but you cannot bypass it. I likely won't use it. Just will note where it has to be for the bush hog. Not even sure this one's adjustable stop is even there.
One negative that I haven't contended with is the 2 drain points on the crankcase. Will experiment with which one is emptied using my oil extractor. Maybe there's a connect between them at front or back that allows both to be sucked dry. Tried this on the JD 4010. Opened the drain plug and NOTHING came out.
