Looking for “Black pipe dope” advice………...
Sidekick
Jul 29, 2023
1,246
1,791
N.Y,
I read don't use synthetic oil in your compressor if you use pex. The vapors that make it through the pump can destroy pex over time. I worked with a guy that used pvc for his compressor lines and didn't have a problem until trying to sell his house. Banned by code and all had to be removed.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Our mechanical division we had an "incident" while testing PVC piping with air pressure - as required by the specs. I don't recall the size, except I think it was larger than 2" and received lots of attention. Fortunately, there were no injuries. The company VP decreed there would never be any air tests on PVC again, regardless of the specs.
weaponoffreedom
KX91-3 L2501 RTVX900
Oct 8, 2025
nc, usa
Chinese NPT threads are terrible...I use teflon tape and a paste type dope. Gasiola, Resctorseal, and Blue Monster are all good brands.
The above is correct....I will add:
Teflon tape can act as a "shim" of sorts when threads are not exactly to NPT specs. For air, especially with systems that vibrate a lot, the blue paste type works very well, with or without tape. PTFE and teflon is a lube, the threads is what make the seal.....just an FYI
NC licensed Plumber here.
Rectorseal 31300 Quart Brush Top Tru-Blu Pipe Thread Sealant , Blue: Hardware Sealers: Amazon.com: Industrial & Scientific
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,799
2,362
WestTn/NoMs
I'm curious what service required pneumatic testing. The only one I can think of would be sewer, which would be under low pressure.
In my years of petrochem, folks got real excited (in a negative way) when pneumatic testing was brought up.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,799
2,362
WestTn/NoMs
The subject of this thread is air, but if your natural gas pipe dope has to pass an inspector, it better be yellow in many jurisdictions.
weaponoffreedom
Oct 8, 2025
nc, usa
Correct, but also incorrect, by the inspector. There is nothing that prohibits the use of any other color tape.....technically, you are not supposed to use both dope and tape, per manufacture. Yellow tape on other than NG or LP is prohibited.....weird
10,910
I've switched all of my teflon tape use to fastape.
chim
Jan 19, 2013
3,278
2,976
I believe it may have been chilled water for HVAC (because we normally tried to avoid plumbing jobs). The project was at the State Farm Show Building. I texted a bud to see if he remembers.
With your background you probably recognize something we had a chance to play with:
10,910
When I worked in Production facilities they often used schedule 80 PVC for chemicals or cool / chilled water / coolant delivery.
I was on more than one job that has a pop / boom from it failing.
Intel used a stainless pipe inside a clear PVC pipe for boron delivery as it's highly toxic in even the smallest amounts. the second pipe was a containment and counter acting chemical to neutralize the boron.
10,910
I'm getting the pig...
Name that movie!
10,910
When I built my house the sewer lines, the Hydronic heat lines, the Gas lines and the water lines all were under test for an extended period of time, and all the while while the concrete was being poured and finished and then throughout the build till landed at location.
Didn't want even the slightest leak under the 6" to 24" of concrete.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,799
2,362
WestTn/NoMs
I had an ugly, amusing now, encounter with one of those things early in my career.
5,241
Thanks for all the replies guys! (y)
It appears that “Rectumseal" has the market pretty well cornered on sealing solutions.
I decided to try the “Tru-Blu" …….However when I went to Menards, I did’t have my glasses with me and I accidentally picked up some "Blue +"
They must have been either next to each other and I grabbed the wrong one, or it was in the wrong spot.
Either way, when I got home, I noticed it and did not feel like going back, and when I looked it up, it appears that “Blue +” is the same thing as “Tru-Blu” but with some sort of “synthetic fibers” in it.
So instead of going back I tried it.
I “re-did” my original set up and tested it…………….. So far, so good🤞
Thanks again. 🍻🍻
weaponoffreedom
Oct 8, 2025
nc, usa
Thanks again. 🍻🍻
One thing to do with a new off the shelf dope is to make sure it is well mixed.
