Found an L245 4x4 w/loader for sale for $3850. Runs OK, steering link a bit sloppy, decent ag rubber. Looks to have several thousand hours on it. Owner felt that hydraulics were a bit slow, with some weakness. He cleaned screen (was cruddy), changed oil, but not much change. He added a "shim", (pointing to a valve cover under the seat on the left side) that he made by polishing and reaming out a washer. He said it helped some.
What I observed: with the engine revved up, it seems to lift and lower the FEL at what I would judge as normal speed. Verrry slow at medium throttle. Not sure what I should expect. However, I cannot lift the front end (at all) with the lift arms. If I place the bucket flat on the ground and roll it forward ("dump it") it lifts it with no effort.
Seeing as it has power to lift it by rolling the bucket, can I assume the pump and main hydraulics are probably OK. Could it be something in the lift arm controls that need cleaned or adjusted? I'm good at mechanics, but never messed much with hydraulics.
What is the worst I'm up against, money-wise, for fixing something like this? I can do the work myself if I know what to fix! The price seems not-too-bad, but I always look at worst-case-scenario.
Thanks in advance for your thoughts.
