Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
just thought i would share this info with you all just in case someone else happens to need the info.
Its taken me a while to source it but it does answer many question i had regarding B6000 FEL etc, and has helped me in my refubishment/rebuild project of the loader.
This K450B is really well engineered, probably over engineered to be honest, but it is probably the best suited to the B6000 as it also uses the control spool for the 3pt hitch etc, but you can also use a remote spool valve as i am doing.
the standard version just has power lift rams(40mm cylinder rods which are pretty beefy) with a gravity dump bucket, but the upgrade is two way dump rams also which is what i have fitted.
anyway might be of interest.
rob
rob
