loader to SSQA differences...
IDKUBOTA
L3800DT/FEL/BH77 and others
Dec 16, 2012
133
Latah County, ID
Greetings,
I have been wondering as to why some loaders have flat steel attaching the distal end of the rollback hydraulics to both the distal loader arm and to the top of the SSQA and others pin directly to it with no attachment to the loader. I was looking at an L3240 with LA514 which did not have it but another with LA724 does while the L4600 w LA764 does not have it. Many of the bigger tractors seem to have them, but not all do. And it does not seem to be a function of loader size.
Is there a functional advantage to this additional attachment linkage ... possibly more lift since the rollback can get a load closer to the pins or does it stabilize something? I noticed on my l3800 when I was going to place a block of wood at the bent end of the SSQA to straighten it that I didn't have anything to hold the wood in place at the loader end.
Just a curiosity.
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
213
76
Bloomsburg
Most definitely an advantage to the skid steer type (SSQA) attachment. No additional lifting capabilities. If you have or add an additional 3rd function to the loader alot of additional attachments available such as a grapple. If you mow can can remove front bucket so it not hanging out front. Am sure you get a lotta suggestions and information from additional posts.
5,371
It might be as simple as which 'committee' designed it. :)
We can all second guess as to 'why' something is designed as 'a' or 'b', really need to see in person and in action , side by side, so weigh the differences in the design. Frankly, the more complicated unit will cost more up front and in maintenance and repairs...nature of the beast.
re: Most definitely an advantage to the skid steer type (SSQA) attachment
I'd like to know what the advantages are
7,416
The link design gives you greater breakout force.
But with the downfall for greater slop and parts wear and roll is slower.
I'm a fan of the link setup.
5,371
re: The link design gives you greater breakout force.
OK, that makes sense.
Also means they could use smaller cylinders to get 'equivalent' force based upon the 'spec' they were going for ?
