Loader Lift Cylinder
N3BP
Sep 20, 2016
397
148
Lebanon, PA
Hey Guys,
General question relating to lift cylinders. I recently purchases a L2900 that has a Woods 165 DuAl Front end loader. Both from the mid 90's. I had the bucket off today to grease the pins. I noticed when I operate the bucket curl control, only the RH lift cylinder operates until it reaches its limit, the the LH cylinder operates. Is this normal, or should they move in unison? Neither is leaking, and it seems to have a strong curl to it.
Thanks!
Brandon
N3BP
Sep 20, 2016
397
148
Lebanon, PA
Thanks for the replies guys. Since the bucket was not attached when I was operating the control, there was no tie point between the cylinders. I must admit I don't understand hydraulics, but thought they would move in tandem. That's why I asked. So when you attach them to the bucket, it forces them to work evenly together?
Kenny, the cylinder that moved first was the one closest to the joystck, so it would seem less line to get to the cylinder and less resistance.
Thanks
3,075
When the bucket is attached ... they both share the workload equally, as the path of least-resistance is equalized.
N3BP
Sep 20, 2016
397
148
Lebanon, PA
Thanks for the explanation fellows, I'm happy to hear that!
