Loader Joystick Knob
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
298
36
Thetford, VT
Hi-
Anyone know the part number for the BX 80 series loader joystick knob? I can't seem to locate this.
Thanks!
bluedunn
Aug 29, 2019
298
36
Thetford, VT
3,037
Thanks! Yea, that was a typo - sorry! Thanks again for the part numbers.
Do you know if the grip is just a pressure fit or is it threaded and screwed on?
Uhhhh.... does the rod the knob fits upon have threads? Or No...? (Hint-hint)
5,129
I was afraid of that :-(
why afraid?
Heat old knob with a hair dryer to pull it off, or cut if off if scraping it.
To install new know, heat put a couple dots of superglue gel on the inside of the knob and push it on.
bluedunn
Aug 29, 2019
298
36
Thetford, VT
why afraid?
Ok, that doesn’t sound too bad ***128077;***127995; Thanks!
3,037
Almost unrelated... but when the throttle-knob on my M4700DT was totally missing and only a plain, unthreaded rod was there for the manual throttle.... I fortunately found at Tractor Supply Co. a clearance item... a black rubber, rounded knob from a Ford tractor for $1 that was a snug, force-fit.
Looks/Works perfectly. (I had to remove it from its Ford packaging and bring it to the Kubota in a plain, brown bag tho.)
4,393
And as Geo. mentioned, many knobs will work. If they seem too tight you can heat the thing with a heat gun and slide it on.
DevilDog
L3540 HST3, 72" Woods Rear Finishing Mower, L3584" Land Pride BB, 72" York Rake,
Feb 1, 2011
45
upstate N.Y.
This is a great site with knowledgeable tractor owners.
Kudo's to the North Idaho Wolfman, he's always is her to help out issues with our tractors.Great to have him on board.
DevilDog
