loader control knob?
tsmithco
L5740
Mar 7, 2024
OH
I've got an L5740 with a 3rd function - unsure if this is stock or if the previous owner added. But the knob is broken, and I've glued it back together a couple times - it's time to just replace. I can't find the part however - Can someone point me in the right direction? Current knob has 2 buttons, and then an "on/off" button halfway down the shaft (see pics)
kubotafreak
Sep 20, 2018
1,044
390
Arkansas, US
Coleman has it for a few $ less. Kubota prices are ridiculous when they don't manufacture the part. I have run into it a few times. If you can just find the original manufacturer, and buy theirs.
I would suggest looking on ebay if you have patience. You can probably snag one with the wiring, and switches for 60$.
JimmyJazz
1,203
723
Pittsburgh, Pa
A proper built up application of quality epoxy would solve the problem ,be stronger than new , and eliminate having to possibly monkey with the wires and switches. I use the West System brand. Its primary use is for patching hulls on boats. Works great. Good luck.
tsmithco
L5740
Mar 7, 2024
OH
used a plastic glue last time. This time I used jb weld. Will see how it holds up. Thanks!
