Lightbar to Cab?
Jday
Kubota l4701
Jan 4, 2022
81
66
Bought m7060 cab last year. The lights are not great. What’s easiest way to add lights. Was thinking light bar front and back. Dealership wants to charge 3k. No way it should cost that much. I looked in search bar with little success? Any help appreciated.
mcmxi
5,309
NW Montana
$3k is ridiculous for a light bar installation. It's simple enough to make your own bracket to support a light bar of your own choosing. I have a thing for Vision X products and have their light bars on my F250 and Jeep TJ as well as their 7" round lights on the Jeep and the LMTV M1078.
Given the cost of Vision X stuff I wouldn't add them to my tractors, but I do have some nice LED lights to install but haven't got around to it yet. I did start to make a bar that bolts on either end to the factory light brackets but didn't finish it yet.
It wouldn't be hard to make two support brackets so if you're interested send me a PM and I can make something up ... for a reasonable fee.
Jday
Kubota l4701
Jan 4, 2022
81
66
Thanks was hoping to plug into current lights and switches. The said I need to put extra 100 amp alternator but LED don’t draw much. Just looking what others have done.
NorthwoodsLife
Oct 15, 2021
1,028
975
Wisconsin
Are the factory front and rear cab lights not bright enough?
Do you have the factory front and rear cab lights?
I do. And they work fine.
Work thru the dash switch.
Plug and play.
Definitely not 3K.
If you have the factory lights and they are not good enuf, find a cheap led light bar and splice it in.
The worst you could do is blow a fuse.
Jday
Kubota l4701
Jan 4, 2022
81
66
No they aren’t enough for me I know how much brighter led would be but thanks yes thinking that is best way.
lynnmor
B2601-1
May 3, 2021
1,365
1,071
Red Lion
If you want to reduce the draw on your current alternator, replace the incandescent lamps with LEDs, that way you will have even better lighting and allowing more amps to be available for the added lamps.
jaxs
B1750HST
Jun 22, 2023
538
285
My thoughts exactly,LEDs instead of not in addition to is a win win.
4,173
I mounted my LED warning light bar directly to the roof of the cab and sandwiched the bolts with large fender washers and rubber washers, lock washers, and nuts. Been up there for 2 years and it's great. I will be doing the same with some smaller LED fixtures to augment the Kubota cab LED lights.
3,248
The problem I’ll predict with that plan is…… LED Lightbars pull more Amps than you might think…. about 10A each. You should probably plan on a small 40A relay ** at the very least if you want to use existing switches….and that will still require dedicated power to the lightbar.
** https://www.amazon.com/gp/product/B017VDI0GY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,873
969
Near Lancaster, PA, USA
The OP's dealer sure wants to make a buck!
Boring stuff for veteran posters here but may be useful to some of the newer crowd:
My tractor had factory lights on the front of the cab, and nothing on the rear. Posters here revealed that the tractor had the rear wiring from the factory (hidden under taped-up wiring to the amber "lollipop" flashers). There's a connector behind a blank in the headliner for the rear work light switch. Switch just plugs in to the connector.
I replaced the two factory work lights on the front and added a couple on the back as well as a couple in the grille guard - all with Maxxima MWL 42's. Then to get some good side lighting I added a cube on each side tucked into the loader frame tube.
The 2,100 lumen Maxxima lights each draw 2.4A which is slightly less than the 35W factory (filament) lamps.
Here's more of the story:
Brushbuster
Kubota LX2610
Apr 4, 2023
9
Minnesota
I have a non cab LX2610. I replaced all the OEM bulbs (headlights, turn signals) with LED bulbs. I bought a light bracket to mount 4 LED lights on my ROP's. I made sure the OEM rear outlet would handle the wattage which it does. I then installed a light bar on the front of the tractors grill guard (which protects objects from penetrating your radiator grill) using magnets which screw into the light bar. I had to run wires to a switch I installed on the dash, back to a relay and then to the battery. They all work awesome and a huge improvement over the OEM lights. I believe the light brackets were purchased from 911 as well as the grill guard (which obstructed the headlights).
