Level trenches
Brick Axelrod
L5460, BH92, RCR1872, FDR2572.RTVX1100c
Apr 12, 2018
137
9
South Carolina
I’m not super experienced on my BH 92. I can remove stumps, dig holes and stuff like that. I now need to dig 3 100 foot trenches and keep them level. Any tips would be appreciated.
Brick
4,430
When digging a trench with a backhoe, once you get started and down to the depth you desire have the bucket flat in the bottom and pull up taking the edge of the untuched dirt. Just like you're playing in the sand as a kid, scooping with your hand. Curl you fingers and pull up. Same procedure with your backhoe.
When you put the bucket back in the trench have it flat on the bottom and roll it up. Once you have a process it becomes pretty easy.
eipo
L4060
Dec 1, 2015
693
81
MI
Level as in flat or level as in consistent depth following existing grade?
The easiest way to do it is paint a line on the front edge of the bucket facing you at whatever depth you want to dig your trench. Couple that with what D2 told you and you're almost guaranteed to have a consistent depth trench.
Brick Axelrod
Apr 12, 2018
137
9
South Carolina
Level as in flat for 100 feet.
2,205
Your gonna need a transit.
or an AUTOLEVEL.....or a laser level....
and you will need help maintaining the grade too via either one.
If for a concrete footer - you can use 57's to get the grade back up if'n you get a little low;)
5,265
For your septic leach field you'll need to dig it a little deeper and shade the lines to get them level. ;)
shootem604
Apr 23, 2018
875
British Columbia
I just dig it a little too deep, and then backfill as necessary and check with the laser level. Seems easier than trying to dig it perfectly.
Brick Axelrod
Apr 12, 2018
137
9
South Carolina
Got this done this week, took a couple of days off. Bought a laser with receiver and a friend of mine checked the depth while I went along. Wasnt that hard at all just took a couple of days with my 16 inch bucket since I had to make 36inch trenches. Thanks for the advice guys. Glad that jobs over. Oh it too this long since first posting because it rained like every 2 days since I posted. This was the first 4 day stretch I had to get everything done.
4,430
That is NOT what you want to get in a habit of. Any “trench” floor should remain virgin material. You never want any trench floor to settle.
Teach me your reasoning. The jobs I worked on, the pipe was laid in the ditch (it was usually long joints) and bedding provided to make level as measured by transit.
This explains it.
"Rigid Pipe is designed to transmit the backfill load on the pipe through the pipe walls to the foundation beneath the pipe. The pipe walls must be strong enough to carry this load.
A line load at the top and bottom of a pipe is the worst possible loading case. If the load can be distributed over a large area at the top and at the bottom of the pipe. the pipe walls will not have to be designed as strong as for a line load. The backfill load is normally well distributed over the top of the pipe. However, proper pipe support must be constructed on the bottom of the pipe to distribute the load.
Proper soil support under the bottom of the pipe is also necessary to maintain grade (elevation) of the pipe. Continuous, uniform support under the pipe prevents unequal settlement of the pipeline.
If a rigid pipe is overloaded, or if the load is not distributed around the pipe, a rigid pipe will fail by cracking"
Here's a link to The Dept of Interior Bureau of Reclamation's technical bulletin. Look on page 16 for a picture. https://www.usbr.gov/tsc/techreferences/mands/mands-pdfs/pipebed.pdf
groomerbuck
137
Palmerton, Pennsylvania,
This explains it.
Im not quite sure what reasoning your looking for?
4,430
I simply asked you to explain.
One person stated over dig and backfill as necessary. You stated, "That is NOT what you want to get in a habit of. Any “trench” floor should remain virgin material. You never want any trench floor to settle."
You also said, "Also keeping your bucket flat is probably the worst thing to do when digging out a trench. Its a horrible habit to get into for several reasons."
