Lets talk “Security”………..
Chanceywd
Mar 26, 2021
881
872
central ny
Interesting discussion as to timing. A couple years ago I put in some Yiiot wifi cameras and although a pain sometimes they did what I needed, to be able to check on pups in house and kennel when I was away for a few hours. Recently they put the push on for you to go cloud , I was using sim cards. Now I can't get in without the sales pitch then ads for other stuff and then only get to see 60 sec of live feed.
I gave up and found Zosi a cctv style system on ebay.
Using its own DVR w/ hard drive and a monitor I can record and set each camera to suit my needs. I have some movable ones like the wifi style coming but still wired
So it came this week and it is a wired system stand alone and doesn't need internet but you can connect to your ethernet and then access with phones. I did a set up to try it and got the phone access to work, no ads no push for cloud. Also supposed to be able to see on my laptop if I set that up.
Hope it continues to function as advertised.
Working out my installation ideas including pulling 2 cable to the garage about 110 ft away. I have a couple 3/4 pvc conduits buried and I checked the BNC cable ends will go thru, should be able to pull 2 in one conduit carefully so I can have one inside and one out.
One other advantage with a stand alone system is when my internet goes down and it does this will still work at least from the house. With the wifi ones I had nothing until it came back up.
Just another idea,
Bill
5,596
Sounds like wifi is the issue. As security cameras are dime a dozen.
I agree.
The original intent of this whole “endevour” was simply to be able to monitor the temp in the house. My thermostat will (supposedly) send me email alerts if the temp drops to pre-specified temp.
I have schedule the internet install for later this week.
From there, the wife complicated things by wanting cameras, but I feel like her interest is waning, and she has not done any ‘research’, so we will see.
I am not a “tech'y” guy, and am easily frustrated when “technology” does not work the way I want it too.
My best bet is to find a “reasonably priced” 2 camera, simple system, install it, and “see how it goes”.
This will give me a “base line” for what I like and don’t like.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
352
538
NC
I agree.
I'd recommend looking for 4k cameras at a minimum as the higher resolution is very helpful when you need to pull up footage to identify someone or a vehicle. A UPS (battery backup) is also nice if you lose power often, but that's a separate battery you can buy at a later date. I've been running cameras of various makes/models for the past 20+ years and have stopped using wifi cameras as they just didn't last that long before crapping out. In the end, I spent the time to run wires (I have attic access, very helpful) and hardwired cameras to a central hard drive. DVR and NVR systems both store your information locally and not on a cloud. At that point, you have the choice to access your hard drive remotely if you want via an app on your phone or computer.
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Milwaukee, Wisconsin, U.S.A.
Looking into this further, ReoLink seems to be quite good quality at very reasonable prices, independent of the Internet, and not found to spy on users. Two years from now budget camera images in 2028 will rival today's industrial-grade camera image quality in 2025 due to advancements in technology and manufacturing, so for the price the quality budget camera is a better investment in my opinion. If one dies two years from now you replace it with another quality budget camera with 2 years advanced image quality and still save $100 per camera, though chances are a ReoLink will last 7-10 years.
And I agree with wired vs wireless, radios in budget wireless devices don't last more than a few years before heat cycling affects the heatsink compound and they tend to burn out. Industrial cameras tend to have bigger heat sinks and expensive heatsink compound so heat dissipation is far better and the WiFi radio lasts far longer.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
841
NE FL
If you want outdoor cameras I would choose a battery powered camera with a solar panel option to keep it charged.
IMO wifi cameras are so much easier to deal with. No wires or hard drives. Just connect via an app and put it wherever you want.
xrocketengineer
Nov 14, 2020
921
886
Merritt Island, Florida
My general suggestion would be to buy one stand alone camera with SD card recording (your choice of brand) and at least 1080p resolution with no subscription required. Try out how it works in different locations. Checkout operation with a computer or phone. Find out its strengths and weaknesses and figure out if that makes you happy. You don't like it, not much is lost. That is what I did. If it works for you, keep adding cameras as you need them.
A friend of mine bought a set of wireless cameras with its own monitoring base from BJ's and it was a disaster. The cameras had a hard time connecting with the base with constant dropouts and to make things worse, the camera system wireless frequency interfered with his internet Wifi. Fortunately, he managed to return them but he spent a lot of time frustrated trying to make them work and figuring out why his Internet sucked.
5,596
Looking into this further, ReoLink seems to be quite good quality at very reasonable prices, independent of the Internet, and not found to spy on users. In two years the budget camera images will rival today's industrial-grade camera, so for the price the quality budget camera is a better investment in my opinion.
And I agree with wired vs wireless, the radios in budget wireless don't last more than a few years before heat affects the heatsink compound and they tend to burn out. Industrial cameras tend to have bigger heat sinks and last far longer.
Thanks for posting that.
It helps answer some of the “basics" for me, and gave a good general overview of some of the available budget minded cameras “Strengths Vs. Weakness’s” . (y)
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Thanks for posting that. It helps answer some of the “basics" for me, and gave a good general overview of some of the available budget minded cameras “Strengths Vs. Weakness’s” . (y)
For me too! Discussions here led me to find that, I'm in much the same boat!
Here's how to save money on ReoLink:
I've found the same situation as in the video on other cameras where higher resolution doesn't produce a better picture. In the cameras I looked at for a different application, mid-tier camera manufacturers are using the same lens as on their less expensive models and the lens isn't high enough quality for use with higher-quality sensors resulting in no real image improvement. The solution for me was buy the highest quality lenses for the application, but in security cameras everything is integrated, so until manufacturers improve their lenses, last year's camera is generally a better option, especially at the discounted price.
WI_Hedgehog
Apr 24, 2024
1,130
1,647
ReoLink's major shortcoming: small image sensors making for low-quality night images, possibly requiring adding a different camera brand for night imaging. One solution for in the woods might be an infra-red floodlight, which should also keep spiders off the front of the camera (without buying a $1000 Axis or $1500 Sony camera):
Old Machinist
May 27, 2024
723
841
NE FL
I don't see the Reolink night quality as all that bad. Here is a night shot from one of their lesser 1080P cameras. Their infrared reaches out 90 feet or so.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
208
287
Hardy, VA
I agree.
I have the Blink system at my remote property and each camera will reveal a temperature. They are cheap, easy to setup and with the XR plus mode - I have two at the dock and one at the gate all making contact with the Sync module. They are battery operated, small, and unobtrusive. They are not as nice and richly featured as the Google Nest cams I have at home, but they do the job for a good price.
5,596
My daughter also suggested those. She has them and like you suggest, they are “cheap and easy"
For less than a hundred bucks, (50’ish for one camera) it’s probably the best way to “get started”.
trikepilot
Jul 18, 2020
208
287
Hardy, VA
They are all that. Be sure you do your research into the different sync modules and how they interact with the various models of cameras in the XR and XR+ modes. This may - or may not- have some bearing on how you select your Blink system dependent upon how far spread out you want to place the cameras and have them connect and what features they have when they connect. Overall, I am very pleased with how the blink system turned out for me and the cost incurred
