Cstock5468
L3560 with loader, BH92, LP post hole auger, LP box scraper, Front PTO snow blow
Was frustrated that headlights did little when FEL was on and it was dark and that the work lights did not help much. Installed LED light bar on front and back and replaced the work lights with LED versions (whole lamp, not just bulbs). What a difference! I used easy to install light bar frames from Specialty Repairs in Canada and LED lights sourced on Amazon and Northern Tools. I was able to use the Rear defogger circuit (Defogger option not installed), that had a 40A relay and slow blow fuse already wired up. I obtained a Kubota light switch and was able to wire it up (had to take cab roof off for this). Added up the total amps needed based on LED watts at 12V and it looked like I could have added the light bars with separate circuit, but felt it safer to run these through thier own relay so not to put existing switches at risk of overheating due to added Light bar amperage draw. I drilled holes in top frame as needed for light bar wiring access and used rubber grommets for water seal of wires going in. It took a bit to figure out the wiring of the light switch with the existing Defogger wiring, as the wiring diagram seemed to have one error on wire color on it, but using a voltmeter, was able to figure it out. Tractor is Kubota L3560 HST. If anyone wants more information, feel free to post.
