Leaking oil or coolant
johnfrazier99
Bx23 MLB
Jun 7, 2026
Maryland
Evening all! I have a bx23mlb so basically a bx23d that in the last two weeks has begun leaking oil or coolant. In the attached photo you can see it is wet around the pulley that is seated behind the radiator. I took the radiator out last week and changed the fluid for what to my knowledge was the first time. I could not see anything that looked notably damaged. With it being the original coolant that is why I’m unsure if it’s oil or coolant since the coolant was very dark prior to draining. There is a slow drip when the tractor is off right behind the oil pan where there is a 45 degree ramp on the bottom of the frame. Think it is the water pump but not a hundred percent sure. Any ideas would be greatly appreciated
whitetiger
Nov 20, 2011
3,562
1,994
Kansas City, KS
It looks like a coolant leak from the weep hole behind the pulley.
Before you do any work on it, wash that nasty, filthy engine off.
2,961
Would that indicate that the water pump seal has failed and the water pump must be replaced? I assume it is similar to a car water pump but just want to be sure.)
5,150
My local auto parts store “rents” cooling system testers….
Maybe you could rent one, and if it has the correct adaptors, you might be able to pressurize it in order to test it?
For a few bucks, buying and putting “dye” in the oil then looking with a “black light flashlight” will help find it, if its oil related.
However as previously suggested, cleaning it first is always “best practice”….
……….The parts cannon can get mighty expensive to start firing off……(ask me how I know ;) :unsure:)
johnfrazier99
Bx23 MLB
Jun 7, 2026
Maryland
Wouldn’t believe me if I told you it’s washed after every cut 😂. Water pump is arriving today will give her a good bath with dawn after installation
Killer Bee
50
70
Show-Me State
all good points above.
clean area where suspect leak is so it can A. be determined what it is and B. exactly where it's coming from.
if you're having trouble identifying fluids, gently dab some of it on a cotton swab or clean white cloth, being careful not to scrape engine grime in with your sample. bring it out to good natural light and you should be able to tell what it is, or at least compare it to the color and condition of current fluids in the engine.
if you don't have a pressure washer, plenty of 'steam clean in a can' out there like gunk foaming engine cleaner/degreaser that can be rinsed with a garden hose sprayer.
pressure testing coolant system is the best way to verify leaks. lots of options out there but the basic hand pump with proper pressure cap adapter is more than sufficient. you can slso make one with an old cap, schrader valve, and gauge if you want to watch pressure decay rate.
there are some tricky ones like cold water leaks that seal up when engine warms up but a good pressure test will typically find most leaks.
good luck! 🍻
