leaking hydraulic cylinder
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
157
109
usa
Attached is a photo of a leaking hydraulic cylinder on my bx2357a sweeper. I want to replace the seals, but not sure what seals to order. I find no identifying numbers on the cylinder and don't see a part number in the parts diagram.
I think the hydraulic system was a add on, and don't see a part number for that either.
Do I have to take it apart to determine the bore?
Any suggestions regarding special tools or things to watch for while rebuilding would be most apricated.
thx mike
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
841
NE FL
Is it leaking at the fitting on the head end where you have the cup under it? If so you may be able to just tighten the fitting or replace the o-rings.
If it's leaking around the rod you will have to take it apart and measure the rod seal inside the gland. I have had good luck with 0rings and more for ordering seals by size and type.
nbryan
Jan 3, 2019
1,430
948
Hadashville, Manitoba, Canada
thx mike
My B2782B snowblower lift cylinder began leaking and could not hold position under load anymore, so looked into taking it apart so I ordered the Kubota rebuild kit. The part number I believe is stamped into the cylinder somewhere. I could look the info up if needed, both the cyl and rebuild kit P/Ns.
Once the kit arrived I dove into it and started to take apart the cylinder, to find that one needs likely expensive and specialty tools and the knowledge how to wield them , or I'd very quickly destroy the $800 cylinder completely.
Unless you're knowledgeable, experienced, and equipped properly I'd strongly recommend a reputable hydraulics shop rebuild your cylinder.
I took mine with the kit to Dynamic Machine & Fluid Power 90km from me and the $150 labor bill was WELL spent, IMO!
The cylinder has been rock solid for 2 seasons now.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,940
2,444
WestTn/NoMs
thx mike
You have a BX2537A sweeper with a BX2761 hydraulic angling kit. The parts list shows it as 2"x5" stroke, ~$550 and no repair kit shown. If you can get it apart, you should be able to get parts from a hydraulic shop. It's not welded, is it?
I'd probably measure everything and see if I could buy a new cylinder from Magister or somebody else.
whitetiger
Nov 20, 2011
3,739
2,155
Kansas City, KS
The seal kit part number for a BX2761 angle cylinder is 70001-00872.
marrmanu
Jan 16, 2021
157
109
usa
Thx! looked it up, $60 for several O rings. Messick's does have
installation tips, that's a plus.
marrmanu
Jan 16, 2021
157
109
usa
Thx all.
I got the seals replaced, no more leaking. :) Was actually easy than I anticipated, but messy. One issue was the new seals came with a single seal which replaced a double seal set up and of course it came with no instructions. The new single seal was flat on one side and grooved on the other. Found out the grooved side faces the base end.
Mike
